thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
thorsbro
Jun 03, 2010Aspirant
jmizoguchi wrote: what are u seeing in the router gui when it happens? WAN shows 0.0.0.0?
I can not connect to the router. It is completely unresponsive until the "test" that is amber color turns off. Then I can connect and see that the WAN is not up yet, but after a little while when it is done initializing and negotiating IP everything works fine again.
It is like something makes it crash, and then it recovers by itself.
