thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
jmizoguchi
Jun 03, 2010Virtuoso
I used to see WAN with Amber that lock router because of loss of broadband. I'm on comcast and both FVX58, FVS336 did same in older older firmware. right now I use UTM
I'm not certain if I still had issues when I drop the these model to UTM year ago. seems I may had less experience. I don't recall on single WAN setup with somehow it fail over to WAN2 when you are not using it.
I know when I had issue with amber, comcast either had service issue and dish out p private ip on wan. that usually made the router unresponsive until the the broadband is restored.
If WAN gets 0.0.0.0 instead of private IP in my case with "comcast" I was able to login the router.
