jdehnert
May 13, 2013Aspirant
FVS336Gv1 vs FVS336Gv2
Other than the case, is there any major difference between FVS336Gv1 and FVS336Gv2?
- jmizoguchiVirtuosov2 has DMZ optons now.
- aditMentorand firmware updates...
- Daedalus01AspirantAnd external power supply.
- jdehnertAspirant
adit wrote: and firmware updates...
So the V1 is no longer getting firmware updates?
Makes me worry that if a V3 comes out then my V2 will no longer get firmware updates, or is it just that the V1 has been superseded by the V2 for so long now that the V1 updates have been closed off? - jmizoguchiVirtuosoNetgear.com/EOL
Once EOL it will NOT get firmware.
I would get V2 - aditMentor
Honestly, there are no problems in the 336Gv1 firmware that I am aware of. I have one and have no problems with it. System up Time: 98 Days 01:48:08 The v2 came out and added the DMZ function. Since then a few other features have been added. The v1 may get future firmware updates but there have not been any recent ones. Just because a router goes EOL, it does not mean that it won't get future firmware updates (i.e. FVX538, EOL for 3 years). I would say though that the likelihood is much less.jdehnert wrote: So the V1 is no longer getting firmware updates? Makes me worry that if a V3 comes out then my V2 will no longer get firmware updates, or is it just that the V1 has been superseded by the V2 for so long now that the V1 updates have been closed off?
