Ahiro's avatar
Ahiro
FVS336Gv2 VPN
Hi everybody!   I'd like to buy a VPN Router Firewall to increase our network security.   But i got some question :   - If I buy a FVS336Gv2 VPN Firewall for example, can I configure and ...
  • JohnRo's avatar
    Oct 19, 2016
    Hello Ahiro,
    Welcome to the community!
    I have listed my answers to the questions below:
    - If I buy a FVS336Gv2 VPN Firewall for example, can I configure and use VPN with the Firewall directly or should I install a VPN server behind the Firewall in order to create connection with another network? Does the Firewall got a server inside of it?
    - Yes, the firewall is a VPN server itself. You will configure the VPN settings on the FVS336Gv2 in order for remote devices to connect.
    - If I don't have to create a VPN server, is it free to use VPN? Should I pay a subscription for this service or not?
    - Box-to-box (firewall to firewall) VPN and SSL are free, no subscription needed. For Client-to-box, the only thing you need to buy is the VPN client, no subscription needed as well.
    - What about the bandwidth? Must I pay for the incoming/outgoing data used with VPN to my Internet provider? Does the other network must pay for the data sent and received too?
    - It uses your internet connection's bandwidth unless you opt for a faster internet service I don't believe that you'll have to pay for such thing.
    - Must I use a software in order to send data to the other network? If yes, is there a free software I can use or how much does it costs? Any must have?
    -For client-to-box setup, you need to use our VPN client software. There is a trial version which you can download here.
    Thanks,
ProSupport for Business
