vpnman
Aug 21, 2016Guide
FVS336Gv3 - Help in configuring router
We have a Netgear FVS336Gv3 running latest firmware (V4.3.4-1). The FVS336Gv3 has a single LAN network with 4 devices and each have the following IP address: IP_A, IP_B, IP_C, IP_D. It also has ...
- Sep 14, 2016
Hi vpnman,
Just want to follow-up. Any updates?
DaneA
NETGEAR Community Team
DaneA
Aug 22, 2016NETGEAR Employee Retired
Hi vpnman,
I think you need a switch that supports access control list or ACL on your network setup to achieve your goal. Let me share this article below as reference:
Setting up VLANs & VLAN Routing with Access Control Lists
DaneA
- vpnmanAug 23, 2016Guide
Hi DaneA,
Thanks for your response. Will a Netgear ProSAFE M4100 unit be able to accomplish this and support the additional requirements below?
- In addition to IP_A device, to only allow a particular VPN client (coming from WAN side) with VPN_IP_Z address to access IP_D device and all other VPN clients are denied access to IP_D device?
- Can a set of LAN IP address (ex: coming from a port connected to a WIFI access point) be put in a group and manage this group in a ACL rule (ex: deny this group access to IP_D)?
vpnman
- DaneAAug 24, 2016NETGEAR Employee Retired
Hi vpnman,
About the 1st additional requirement, I believe it can be configured on the VPN policies of the FVS336Gv3. While the 2nd additional requirement, can be configured on the M4100 switch as an ACL rule.
DaneA
- vpnmanAug 25, 2016Guide
Aside from the M4100 switch, can it be accomplished using GS110TP and/or GS108T? Do these support IP-based ACL?
Is there a guide or cookbook that shows step-by-step how to configure the FVS336gv3 to deny access to IP_D device from all VPN clients coming from GW-to-GW VPN but only allow a particular one (VPN_IP_Z address)?
