dsdoyle
Nov 04, 2015Aspirant
FVS336GV3 loses WAN connection
Hello, We have a FVS336GV3 with 2 WAN connections. It appears to lose connectivity on WAN 1 (default connection) too often. I called Brighthouse to see if the issue is on their end, but it is n...
dsdoyle
Jan 18, 2016Aspirant
Hello,
Sorry to have taken so long to get back.
1. I have not swapped WAN1 fro WAN2 because I cannot afford/risk to have my client down again. I have moved the BrightHouse connection directly to the Netgear modem (which has also had intermittent problems.
2. The Brighthouse device is a Ubee modeom/router combo set to bridge mode
3. One connection is Brighthouse and other is Earthlink.
4. Firmware is update on both devices.
5. Block UDP Flood was already unchecked. Any other ideas?
Please advise.
Thanks for your help,
Don
JohnRo
Jan 19, 2016NETGEAR Employee Retired
Hello dsdoyle,
I believe the best way to isolate the issue is to swap the connections between the two WAN ports or connect a device directly to the Brighthouse modem and see if it will give you the same issue. Before changing any settings on the router, it is best to know if the connections coming from the modems are working properly. How often does the disconnection happen? Is there a large number of users when this happens?
Looking forward to your response.
Thanks,
