dsteinbo
Aug 06, 2017Aspirant
FVS336GV3 loses WAN connection
We have an FSV336GV3 Prosafe Firewall. It is using the latest firmware (version 4.3.5-3). It is connected to an Xfinity labeled DOCIS 3 cable modem. Periodically (like once a week at times) it los...
- Aug 24, 2017
Thanks for the feedback. I'm glad to know that your internet connection through the FVS336Gv3 is still up and running.
I research about the logs you posted and found out that these logs are generated when there is malformed packet detected. When a packet with error is received by the interface of the router, it will throw this log and dropping the packet. The 'error code 10' is a length mismatch error.
Since the internet connection through the FVS336Gv3 is now fine and if ever the logs your posted is not of your concern as of the moment, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Aug 10, 2017NETGEAR Employee Retired
Since you have connected the FVS336Gv3 to a different port on the Comcast/Xfinity cable modem, it seems that the cable modem you have is a combination of modem & router. With regard to this, you have a Double NAT scenario wherein a router (which is your FVS336Gv3) is behind another router (the Comcast/Xfinity cable modem-router). I suggest you to set the Comcast/Xfinity cable modem to bridge mode so that the Public WAN IP Address will be registered on the FVS336Gv3. Then observe the internet connection through the FVS336Gv3 if the same problem will occur.
DaneA
dsteinbo
Aug 10, 2017Aspirant
The Xfinity/Comcast cable modem has always been operating in "bridge mode." We do NOT have a double NAT situation. The Netgear firewall/router receives a WAN IP address from the Comcast cable modem. The Netgear firewall/router then functions as the DCHP server for our LAN.
We haven't had the Internet connection fail since I changed which port on the cable modem we are using. We will have to see if using a different LAN port on the cable modem solves the problem (we need to give it at least a week to see if that is the source of the problem).
I will update this post as soon as I have learned anything more.
Thank you!!
