chrisbaker85
Jun 29, 2016Aspirant
FVS336GV3 Services Have Dropped (HTTPS admin interface, DHCP)
We have a FVS336Gv3 at work. We have been having a very hard time getting people's devices connected over wifi as well as a hard line. It may take 5 minutes to acquire an IP, or as long as half ...
Danthem
Jun 29, 2016NETGEAR Employee Retired
Hey,
More likely to be the config or your network I'd say. What is the lease time set to? 24 hours? (default).
That you see clients making several requests may be an indication that the DHCP pool is exhausted... Do you have a lot of people coming and going? If so you might want to lower the lease time to make sure people aren't holding on to IPs when they are no longer there. Do you have any WiFi setup that's unprotected (a guest network or so?).
350 is quite a lot, if the FVS336Gv3 would be enough depends a lot on what the clients are actually doing.
When you can't access the GUI, can you telnet to the unit?
- chrisbaker85Jul 05, 2016Aspirant
Thanks, Danthem, for your pointers. We already had the lease time reduced to 12 hours, and our wifi networks are protected.
Telnet, but it was almost as slow as HTTP(S), so I'm guessing it was simply too much traffic to the device overall, which resulted in a self-inflicted DoS.
I had another demo device collecting dust at home that had higher throughput (200Mbps vs. 60) and offered more connections (30K instead of 10K), so I configured it and installed it overnight.
Perhaps I should get started working on an app. that surveys actual network traffic and tells you which devices can support your traffic load ;)
I really appreciate your help!
--Chris Baker
