JasonStockwell
Oct 20, 2017Aspirant
FVS336Gv3 setting TCP port 35000 and UDP port 35001 not in pick list of services
Setting this up for inbound connection to a Lorex/FLIR LNR632. Able to route/connect on HTTP, but none of the options in pull down menu on service inbound types ie: DNS:UDP, DNS:TCP or RTSP:TCP, RTS...
JasonStockwell
Oct 23, 2017Aspirant
I did make that update, but still not streaming video. Able to connect to system and navigate the menus, just not video. I understand the risk on client. May need to investigate the client VPN option.
train_wreck
Oct 23, 2017Luminary
If you still can't stream, then it's possible that some other port(s) is/are needed to be opened. You could perhaps forward ANY traffic to the camera, then run a packet capture on the Netgear and see which ports exactly are being used.
