johnjvictor
Feb 28, 2017Aspirant
Migrate FVS336GV3 settings to SRX 5308
I plan to replace my FVS336V3 with an SRX5308 to get greater Lan-to-Wan throughput. Does anyone know if I can install the FVS settings on to the SRX as the first step of the configuration?
Thank you. Sounds like I need to plan for a manual entry of the settings.
- JohnRoNETGEAR Employee Retired
Hello johnjvictor,
Do you mean upload the config file of the FVS to the SRX? As of the moment our firewalls does not support cross-platform configuration transfer. The FVS and SRX are totally different in terms of hardware and software, as you can see the firmware versions are different on both. So to answer your question, it is a NO for now.
Thanks,
- johnjvictorAspirant
Hi johnjvictor,
Yes. For now that's the only thing we can do. I'd do screenshots instead of writing everything down. :)
Have a great day.
Thanks,
