Tako30
Jul 25, 2017Aspirant
fvs336gv3 VPN Client Not Working
Good Day People, I am having trouble establishing conection to my office location using the NetGear VPn client software and following the step by step instruction in configuring both the server s...
Tako30
Aug 02, 2017Aspirant
John Carlo
Thank you for your time. There are a few in bound services created but I am not able to disable them due to some services that we are hosting within our network. I have followed the Manual you referred me to on your last post ever since I first created the initial VPN configuraion, and so did you colleague when he was helping me remotely.
Unfortunately I can not get a hold of the VPN license that came with the device (appears someone a the office disposed of it...) I have tried obtaining a new one from NetGear and 3rd party retailers but its nearly impossible to obtain.
Once again thank you for your attempt to help me, I know this is a painful case but I really need to get the VPN working. I am hoping we can find a solution soon.
JohnC_V
Aug 02, 2017NETGEAR Employee Retired
What I mean is "ANY" under inbound rules. Kindly double check that as it may have a conflict on VPN tunnel. You may also try to request a VPN license key with our support team. You may send an email on your existing case, just login to my.netgear.com and go to "My support".
