picgla
Aug 15, 2017Follower
fvs336gv3 inbound rules not working
I have an fvs336gv3, firmware 4.3.5-3. I have defined 9 inbound lan-wan rules similar to the following:
Service Name Filter LAN Server IP Address LAN Users WAN Users QOS Profile Destination Bandwidth Profile Log
ssh-tcp-207 ALLOW always 192.168.2.207 Any NONE WAN1 NONE Always
These rules worked fine until recently, then abruptly stopped allowing any through traffic. I updated the firmware to 4.3.5-3 in hopes that would fix the problem, but there has been no change. All inbound traffic is still blocked. Everything I have tried (rules disable-enable, power cycling, rebooting) to correct this problem has had no successful results. Does anyone have any ideas or specific knowledge that I might try to correct this problem? Thanks in advance.
| 4.3.5-3 | |
i had two problems contributing to this failure.
1) i followed the suggestion to delete all current affected rules and services, then rebooted. after reinstalling the services and recreating the rules, i rebooted again.
inbound rules still did not function. problem was:
2) verify correct external IP with dyndns.
after updating the external dynamic dns address with dyndns.org, all rules functioned as expected.
thank you very much for the suggestions and good leads.
- JohnC_VNETGEAR Employee Retired
Hi picgla,
Welcome to the community!
It seems that this is working before and I see no other issues in here unless there is a new port opened and now having a conflict. These ports should be accessible first in the local network and if it is not working on the local side then it will not work on the public network. Have you ever checked if there is any ports that is having a conflict to your previous setup? Please try resetting the firewall to factory default and re-create those policies. Please also check if these ports are open on the public network using a port scanner.
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- picgla2Aspirant
Thank you for that information. Atleast, you were now able to work with your inbound rules. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
