Vio
Oct 24, 2016Aspirant
FVS336gv3 VPN Failover with two ISPs
Dear all, we got a customer with two sites and each site has a FVS336gv3. Site A and Site B are connected via IPSec VPN (Gateway). On Site A we only have one internet connection. On Site B we ...
DaneA
Oct 24, 2016NETGEAR Employee Retired
Hi Vio,
Welcome to the community! :)
Kindly answer the questions below:
a. Were you able to check the box that says "Enable RollOver?" via the VPN Wizard on the FVS336Gv3 on site B? Check the image below.
b. To isolate the problem, try not to use or disable WAN 1 port on the FVS336Gv3 on site B. Then, just enable WAN 2 port on the FVS336Gv3 on site B for internet access and configure box-to-box VPN with the FVS336Gv3 on site A using the VPN Wizard. Are you able to establish a VPN tunnel?
DaneA
NETGEAR Community Team
