jwake
Nov 08, 2015Aspirant
FVS336Gv3 vs WNDR4500
Apologies if I'm in the wrong section, I could not find a router community. My question is which router should I use as my WAN gateway, an FVS336Gv3 or a WNDR4500? Here's the background... I...
jwake
Nov 09, 2015Aspirant
Hi BrianL,
Thanks for spelling this out clearly. I have scenario 2 now and will probably re-arrange to go with scenario 1. Under this scenario, would you expect that I'll see any degradation of throughput with the WNDR4500 as the gateway? Based on price alone I would have to think that the FVS336Gv3 is a better (faster?) piece of kit.
Also - under this scenario can I have the FVS336Gv3 as the DHCP server, or would it have to be the WNDR4500?
Thanks,
-john
BrianL2
Nov 09, 2015NETGEAR Employee Retired
Hi jwake,
WNDR4500 has better LAN throughput than FVS336Gv3 according to their respective product datasheets. I suggest you test them individually and which comes up better, make it your DHCP server.
Kind regards,
BrianL
NETGEAR Community Team
