JSG_2016
Mar 09, 2016Aspirant
FVS336GV3 WAN stays at "Connection State: Connecting..."
Hi all I'm having problems trying to get our 336 (firmware 4.3.3-5) connect a Comtrend VG-8050 router to the WAN2 port. The WAN2 port is configured for no no login and DHCP. It does indeed get an ...
- Mar 09, 2016
Thanks for both the welcome and the answer DaneA.
What fixed the problem was similar to your proposed action though applied to the router, I flashed its latest firm and reset to defaults once rebooted and reconfigured it worked fine!!!
I'm not sure about upgrading the 336 to 4.3.3-6 firmware though, release notes mentions a single fix to a problem I don't think I have..... ("Routers that have FAILED their PCI Compliance SCANS")
