LeoMJr
Dec 18, 2017Aspirant
FVS316g v2 WAN stays at "Connection State: Connecting..."
I have followed all of the instructions to setup ipv6 on the FVS318G v2 switch and the "IPv6 Connection State:" always says "Connecting...". i have also tested the ipv6 connectivity without the switch, just with the cable modem and that works. However when i add the FVS318G v2 switch and follow the instructions, the ipv6 connection is not working. The firmware version that i have installed is 4.3.5-3... when i look at the "router status" in the WAN Information section, i see the WAN (IPv6) ip address and gateway and status... the "Status" says "DOWN".
How do i fix this? i have looked everywhere on this site and i do not see an answer that does work...
Before going to the ISATAP Subnet Prefix, kindly answer questions below to determine the next action:
a. Who is your IPv6 Internet service provider?
b. What type of IPv6 connection you have? Is it Static IPv6, PPPoE IPv6 or need to set up a DHCPv6? You might need to ask your IPv6 Internet service provider if needed.
Also, you mentioned that your cable modem is a combination of modem and router, I suggest you to set it to full-bridge mode so that it will be a modem-only device. In this way, the FVS318Gv2 will be set as the main router. Configure the FVS318Gv2 for IPv6 internet connection then check if it will work.
Kindly read pages 38-52 of the FVS318Gv2 reference manual here about IPv6 Internet Connection Configuration and WAN Settings.
DaneA
NETGEAR Community Team
- LeoMJrAspirant
correction --- i have the FVS318g V2 - ProSafe VPN Firewall
- DaneANETGEAR Employee Retired
Hi LeoMJr,
Welcome to the community! :)
The FVS318Gv2 is not a switch, it is a VPN firewall router. Let us isolate the problem. Kindly answer the questions below:
a. Is your cable modem, a modem-only device or a combination of modem and router?
b. Have you tried to reboot the FVS318Gv2 and check if it will work?
c. Have you tried to perform a factory reset on the FVS318Gv2 then reconfigure the settings from scratch and check if it will work?
Let me share the following article and forum links below as these might help as reference:
Basic IPv6 WAN and LAN Configuration
Connecting to Comcast with IPv6
WAN IPv6 Prefix Delegation doesn't work
DaneA
- LeoMJrAspirant
answers to your questions:
Modem and Router
Yes
yes
When i follow the Basic IPv6 WAN and LAN Configuration, in the ISATAP Tunnels section there is a question on the ISATAP Subnet Prefix -- what do i enter there?
