jolyoncox
Jan 02, 2015Aspirant
FVS336Gv3 with Virgin SuperHub 2?
I am struggling to connect my new FVS336Gv3 router (firmware 4.3.1-14) to a Virgin Media SuperHub 2 (aka Netgear WMDG480) which is running in modem-only mode. The router status page shows that it fa...
jolyoncox
Jan 03, 2015Aspirant
Nhellie26 wrote: Well, that seemed to be the issue. It is not detecting that you have a connection at all. Have you also tried swapping cables, does the WAN port lit up when you are connected to it?
Yes, that's what I thought, but I was using the same cable as for the FVS318 and simply moving it between routers - and yes, the port was lighting up. I tried using a different cable, but it made no difference.
However, the problem is now solved - see below.
Thanks for your help.
Jolyon
