jolyoncox
Jan 02, 2015Aspirant
FVS336Gv3 with Virgin SuperHub 2?
I am struggling to connect my new FVS336Gv3 router (firmware 4.3.1-14) to a Virgin Media SuperHub 2 (aka Netgear WMDG480) which is running in modem-only mode. The router status page shows that it fails to obtain a WAN IP address via DHCP from the SuperHub. My old FVS318v3 router works fine with the SuperHub, but has to be replaced as it does not have enough WAN/LAN throughput to use the full bandwidth of the cable connection.
Has anyone else succeeded in making this combination work? If so, what WAN settings did you use on the FVS336Gv3? In particular, do the Client Identifier and Vendor Class Identifier fields need filling in, and if so with what values?
Thanks in advance,
Jolyon
Thanks in advance,
Jolyon
