drakerc
Aug 22, 2015Follower
FVS338 - connected to VPN, but can't ping other computers
Hi
I'm connected with the VPN set up on a FVS338 firewall. I connect everytime without any problem, but here's the thing. I can't ping any LAN machines beneath the VPN. However, I can access th...
DaneA
Aug 23, 2015NETGEAR Employee Retired
Hi drakerc,
Just a few questions:
1. What is the current firmware version of your FVS338?
2. What is the Operating System on your PC/laptop where the Shrew VPN Client software is installed?
3. Is there a software firewall or anti-virus running on the PC/laptop where the Shrew VPN Client software is installed? If yes, have you tried to disable it and check if you are able to ping the LAN machines via VPN?
I look forward to your response. Welcome to the community :smileyhappy:
DaneA
Netgear Community Team
