DickPalm
Dec 01, 2016Aspirant
FVS338 and iPhone6 VPN
FVS338 Router Ver 3.1.1-08 Trying to connect an iPhone6 using VPN. Using "Application Notes for IPSec Policy supporting Apple iPhone VPN Connectivity" from Atricle ID: 24236 Does not connect with ...
- Dec 29, 2016
I have posted all of my results.
DickPalm
Dec 20, 2016Aspirant
Don't have older firmware versions.
Mode Config still doesn't work correctly as describe above. Looking at the VPN logs, there are [IKE] ERRORS: No policy found.
Haven't seen any solutions posted from the community or Netgear.
JohnRo
Dec 26, 2016NETGEAR Employee Retired
Hi DickPalm,
I'd like to know if you still need assistance with this one.
Thanks,
- willieaamesDec 27, 2016Aspirant
I spent most of my day trying to get this setup as well. I was able to make the VPN connection from my iPhone over 3G to my FVS338 with the latest firmware. However, once connected I couldn't access any of the devices on the LAN. Also I lost all internet access on the iPhone when my VPN connection was active. As soon as I turned off the VPN on iPhone all internet access was restored.
- JohnRoDec 29, 2016NETGEAR Employee Retired
Hi willieaames,
What firmware version are you using?
Thanks,
- DickPalmDec 29, 2016Aspirant
I'm good. Thank you.
Hi DickPalm,
Thanks for the update. I would like to know how you were able to fix the issue. I believe other users will benefit for your solution.
Thanks,
- JohnRoDec 30, 2016NETGEAR Employee Retired
Hi DickPalm,
Thank you. Please mark the appropriate reply as the “Accepted Solution” so others can benefit from the solution.
Thanks,
