Tridac
Feb 13, 2019Aspirant
FVS338 Not Forwarding Packets
FVS338 Port Forwarding Failure
Hi,
Posted this query on another forum, but it's been suggested that I post it here. A port forwarding problem, started with an FVS318, now an FVS338, neither o...
Tridac
Feb 19, 2019Aspirant
Hi,
Bump, or is there a solution to this problem ?. Have tried everything I can, but if Netgear can't solve it., then I guess nobody can....
Chris
Nodism1125
Feb 20, 2019NETGEAR Expert
Set up a static route on router2 helps your packet route to router1.
- TridacFeb 21, 2019Aspirant
Hi,
Thanks. Have already setup the default route for the wan side, so why should I need an added route for a port forwarding setup, when there i no mention f that in the manual ?. The current setup and data flow is:
router1 @ 192.9.200.254 <> FVS338 router 2 @192.9.200.251 < port forward to > 10.10.10.150
Check out the upthread screenshots for correct setup, but can't see anyting out of order. Fact is, it doesn't work as per the manual.
No more time to spend on this now, so will use opnsense on an old alix box, which should get the job done and already in use elsewhere on the network. Just like these old 318 and 338 routers. Compact and usually fit and forget once setup...
Regards & Thanks,
Chris
