EvilEgg's avatar
EvilEgg
FVS338 port forwarding with incoming port different than port used by application
Is it possible to have a different incoming port than the application, and have the router resolve it?   Here is my current setup, we have 2 different servers, both are listening on the port 3389 f...
  • JohnRo's avatar
    JohnRo
    Jan 22, 2016
    Hi Evilegg,
    If that is the case then you'll have to use the "Translate to Port Number" option. After selecting the service name (for port 3390), select the Action, Add the LAN IP of the service and click on the tick box for Translate to Port Number (enter 3389) and the Apply the settings. See image below for reference:
    Thanks,
ProSupport for Business
