BPR
Jan 13, 2017Aspirant
FVX538 - Broken ... anyone know where to get replacement motherboard?
Not sure of Hardware version. Bought two of these FVX538 routers a 10 years ago ... was told they were Version 2. Label on bottom of case says Version 2. But, neither worked reliably with most...
JohnRo
Jan 13, 2017NETGEAR Employee Retired
Hello BPR,
Welcome to the community!
As far as I know we do not sell parts unless they are considered as accessories (SFP modules, antennas, etc.). We do not sell these internals parts and we do not recommend opening the unit since it will void the lifetime warranty of the unit. If ever there are parts being sold, they are from refurbished or used units.
Thanks,
- BPRJan 13, 2017Aspirant
Thank you JohnRo!
Warranty ... ah, well these are refurbished units with a 30 day warranty ... bought sometime around 2006.
One still works, but the second one stopped working a year or two ago. I opened it up to see if there was anything that I might be able to do to fix it. Looks like only two easily replaceable parts ... the Power supply (still good) and the PC board ... which I probably can't get now. But, maybe someone else has one with a broken Power supply?
I'll wait to see if anything can be done to fix it ... and throw it out if it looks like it can't be fixed ... in a few more weeks. :)
- JohnRoJan 13, 2017NETGEAR Employee Retired
Hi BPR,
You're welcome! I see what you mean. :) Hopefully, someone still has them, we don't manufacture this model anymore. It's a good router with a few extra ports for WAN and LAN and a console too. I saw a few units still being sold on Ebay, but I'd just recommend to get a new one with a full warranty.
Goodluck!
Thanks,
- DaneAJan 23, 2017NETGEAR Employee Retired
BPR,
If ever you decide to replace the old FVX538 and check on the NETGEAR ProSAFE VPN Firewall Routers available in the market today, let me just share you the data sheet here. It shows the specifications and comparison of the FVS318Gv2, FVS336Gv3, SRX5308 and FVS318N.
DaneA
NETGEAR Community Team
- BPRJan 23, 2017Aspirant
I will wait for a few months to see if I can find a replacement motherboard.
I don't need anymore routers now ... have several hundred sitting on the shelf.
I already have a few dozen FVS318's ... mostly model 1's ... a few model 2's and two Model 3's ... I don't think any of these will be able to cope with the WAN<>NAT data rate requirements that I'm seeing now.
I also have a few dozen FVS124G's but they seem to restrict the WAN<>NAT throughput to less than 15Mb and aren't really usable on most Highspeed ISP connections anymore.
But, I do like the simplicity of the FVX538 and would like to see if I can recover it. It does seem to be able to process WAN<>NAT traffic faster than a 40Mb ISP connection ... not sure how fast it can go yet though.
