fdurdanivia
Oct 28, 2011Aspirant
FVX538 dual-port problem
I have the following issue WAN1 I have connected to an ISP which is PPPoE dial, just connect in the WAN2 port another ISP that uses IP, at this point I have no problem, 2 suppliers connect correc...
fdurdanivia
What version of firmware do you recommend??
And because of your help, load balancing, if you lose the connection of one of the ISP, you can keep browsing with another ISP?
Thanks
Thanks
