Dookie_Brown
Sep 26, 2018Aspirant
FVX538 v2 - Looking for new replacement
I manage a small biz router FVX538 v2.
We are looking to upgrade. What I am looking for is a replacement router that has the same features/capabilities as our current FVX538 v2.
Can someo...
JohnC_V
Sep 27, 2018NETGEAR Employee Retired
Hi Dookie_Brown,
Welcome to our community! :)
Unfortunately, NETGEAR has stopped producing firewalls. We still don't have any update if it will be continued.
- Dookie_BrownSep 28, 2018Aspirant
OK, so I will look at the BR500.
One of the firewall features we need is the ability to granularly open SMTP ports to the WAN/Internet but only ALLOW it to talk to a specific IP on the internet on said SMTP ports.
We don't want the SMTP ports open to the inet world, just one mail server on the internet.
Also need the dual WAN ports to donfigure failover/take over if a WAN connection goes dead.
- JohnC_VOct 01, 2018NETGEAR Employee Retired
Yes, you can open SMTP port to the WAN and communicate it with your specific mail server. Unfortunately, it has only 1 WAN port and we cannot configure fail-over for this router.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
