HNGO
Dec 15, 2021Aspirant
Help - two firewalls on same network
Hello, I'm having issues setting this network up, as I think it should be simple. I have two firewalls, SRX5308 and UTM 50 and I want to use the SRX5308 as a VPN only and the UTM50 as a DHCP. -...
HNGO
Jan 07, 2022Aspirant
Thanks,
So i currently have it setup like this:
Main Firewall Setting
IP: 192.168.0.1
SM: 255.255.255.0
DG: 192.168.0.1
DHCP Range: 192.168.0.2-240
VPN Gateway
IP: 192.168.0.10
SM: 255.255.255.0
VPN Clients: 192.168.1.10-20
What route should I map out on the Main Firewall?
Thanks in advance once again.
schumaku
Jan 07, 2022Guru - Experienced User
Well, all your LAN clients are using 192.168.0.1 as the default gateway.
If the VLAN IP subnet is not NATed, but becoming available direct, you need to add a route on the default gatway routing 192.168.1.0/24 (for simplicty, I would not subnet any further) pointing to 192.168.0.10.
- HNGOJan 07, 2022Aspirant
Thanks,
I'll give that a try.
Cheers!
- HNGOJan 11, 2022Aspirant
Good morning,
So i'm having some strange issues:
PPTP - Remote users are working great and no issues
*** I didn't configure any routing routes
VPN (IPSEC) - I couldn't setup on the Gateway VPN
- Remote users can connect to the network and get a local IP address but cannot access network resources.
Route I added to the default/main firewall:
192.168.0.0 point to 192.168.0.10
Any suggestions?
Many thanks
