vpn-help's avatar
vpn-help
Help Connecting with the VPN Client
Netgear support did a wonderful job helping me configure the hardware and VPN Lite on one Windows 10 computer (Case# 40683367) but I would like to install the client on an additional computer but I'm...
  • DaneA's avatar
    Dec 06, 2018
    Hi vpn-help,
    Welcome to the community! :)
    It seemed that your concern is similar to the article below.  Kindly access and try the steps indicated.
    Error when activating VPN Client software on Windows 8
    If ever your concern got resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
