mansus's avatar
mansus
R7800 wireless clients cannot connect to lan clients
Hello,
I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning off the router but that doesn't help. It seems that 50% of the traffic gets blackholed somewhere. LAN-LAN works just fine. WiFi-WiFi works good as well. But WiFi-LAN doesn't want to work.. Any ideas?
  • evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
    Thx, Mansus.
