rlusw
Sep 14, 2015Follower
How do I connect to my satellite modem GUI on WAN side from LAN side of FVS318N?
I have a TooWay Satellite modem that is controlled via 192.168.100.1 connected to the WAN port. I have a MAC and other equipment on the LAN side. LAN side is all fine I have a 192.168.1.x IP range b...
Sophostry
Sep 15, 2015Aspirant
You shouldn't use such a big subnet mask. In the case of most modems, if you have it ahead of the main router, and they are on different subnets, it will let you access it at the 100.1 address, even if it is giving your router a public IP address. This isn't always the case. This is why usually people recommend to bridge / DMZ the modem to the router, depending on the options, so you only really need to configure or adjust one device, instead of 2 for everything you do. Makes life simple :)
