NetworkDude696
Mar 19, 2019Tutor
Orbi Satellite dropping connection
I am having issues with my Orbi Satelitte. My orbi satelitte is connected directly to my computer through ethernet. It is about 15 feet away from the main unit and modem. When I connect my computer through wifi and turn the satelitte off I have no issues. When I use the ethernet or if I am connected through wifi to the satelitte I get consistent packet loss about once every 30 minutes. It does not appear to be my ISP or modem as far as I can tell since when I am connected via the main router the issues don't happen. I beleive my unit is defective.
I have tried to do the following:
Move the satelitte to different locations (doesn't seem to help)
Done a hard reset of the satelitte (doesn't seem to help)
I can provide any logs or other data needed to help troubleshoot.
I did update my firmware. I used a direct connection using ethernet from my modem to my computer without the Orbi at all. I then captured the exact moment the issue happened twice with wireshark. I watched packet loss happen directly on my other screen in wireshark. I think at this point its obviously not the Orbi and I need to get the ISP invovled. I am sure its a cabling issue from the drop line to my place.
I appreciate all the help! I am glad its not the Orbi!
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
15 feet is a bit too close. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).What FW is currently loaded? V2.2.1.210
What is the Mfr and model# of the ISP modem the NG router is connected too? Netgear Model: C3000
Is the Orbi system operating in Router or AP mode? Router
What is the size of your home? Sq Ft? 1500
15 feet is a bit too close. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. I previously had this further away but the connection issues made me try closer.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. I am manually set to 11.
Any Wifi Neighbors near by? If so, how many? 8 different networks by me.
What WPA security modes are you using? WPA2-PSK [AES]Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I have disabled all of the above and mimo/beamforming are checked. I didn't see an option for 20/40Mhz Coexistence to make it 40mhz only so I disabled it assuming thats what you meant. I will test some more with these settings.
Yes, unchecking the box makes for 40Mhz only.
See if anything changes. Distance should be starting at 30 feet.
Is ALL wifi on the C3000 disabled? Make sure it is as this is a modem/router combo unit.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAlso there is newer FW available:
