rlusw
Sep 14, 2015Follower
How do I connect to my satellite modem GUI on WAN side from LAN side of FVS318N?
I have a TooWay Satellite modem that is controlled via 192.168.100.1 connected to the WAN port. I have a MAC and other equipment on the LAN side. LAN side is all fine I have a 192.168.1.x IP range b...
DaneA
Sep 15, 2015NETGEAR Employee Retired
Hi rlusw,
I would assume that the TooWay Satellite modem is a modem-router combination. I would suggest that it would be best if you set the TooWay Satellite modem to bridge mode so that the WAN IP Address will be registered to the WAN port of the FVS318N.
However, if my suggestion above is not possible, kindly try this: On one of the Windows PCs on the LAN side of the FVS318N, set a static IP Address that is within the LAN subnet range of the FVS318N. For example, the FVS318N is on 192.168.1.1 then set a static IP address of 192.168.1.2 on the PC. Then, add another static IP address that is within the LAN subnet range of the TooWay Satellite modem. For example, the TooWay Satellite modem can be access via 192.168.100.1 then add another static IP address of 192.168.100.2 on the PC. Then, check if you can access the web-GUI of the TooWay Satellite modem while the PC is on the LAN side of the FVS318N.
Refer to the screenshot below on how you could add mutltiple static IP address on a Windows PC:
Hope it helps. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
