stevefigueras
Dec 19, 2014Aspirant
How forward port on FVS318G ?
Hello i need to forward port 443 on my FVS318G for watching an Ip Camera from web.
This FVS318G is behind a internet box and the ip cam have a 192.168.1.8 fixed adress.
Can you help me ?
Can you help me ?
- aditMentorCheck to make sure Remote Management is not on 443.
- stevefiguerasAspirantRemote is on 8080 and is not enabled thanks for good security advice :)
If you're ok to help me a little bit more i need to know how i can forward the 443 port for 192.168.1.8.
I have a ddns with this camera so i need to access from outside. - NhellieVirtuoso
stevefigueras wrote: Remote is on 8080 and is not enabled thanks for good security advice :)
Hi Steve,
check page 71, figure 4-8.
http://www.downloads.netgear.com/files/products/FVS318G/Documentation/RM/FVS318G_RM_27Aug10.pdf
Service: HTTPS
Action: Allow Always (or by schedule if you prefer)
Send to LAN Server: (Single Address)
Start: 192.168.1.8
Translate to Port: (leave unchecked)
WAN Dest. IP: Broadband
LAN Users: (Default) ANY
WAN Users: (Default) ANY (or specific WAN IP)
Log: (you can enable this if you want to see the logging)
Bandwidth Profile: none - stevefiguerasAspirantHello thanks for your time i follow your advice but the port wasn't indicate as open so i try other solution as you can see.
Thanks again - stevefiguerasAspirantHello sorry but i need your help to resolve my problem.
I do exactly (and only so i remove DMZ WAN Rules & LAN DMZ Rules) and it's not working :(
What does it mean WAN1 Destination when i specify Broadband ?
The 3504 port is shown as open on internet.
Thanks to help me. - NhellieVirtuoso
You'll only have to do DMZ on the greenpacket router, leave this on. Set the IP address that the FVS318G router is getting on the DMZ of the greenpacket.stevefigueras wrote:
It appears that WAN1 is the WAN port being used. This is where your internet connection comes in so this is where the rule is applied - stevefiguerasAspirantHello first thanks you to help me :)
I show you here what i've done on Ip CAM, on ISP box and on FVS318G.
But when i enter Public IP:3504 or Dydns:3504 embed with camera, nothing work :(
I precise i try from nomad access not linked by wifi or ethernet to my isp box to avoid looback if my FVS318G don't support it.
I search about explication :
On LAN when i enter 192.168.1.9:88 : it work no problem but if i choose the 3504 port there is an error and nothing happen...
Do you know if my operation on screen capture is corect ? - SamirDProdigyAfter looking at your most recent set of screenshots, it looks like the port is open, but the camera is not responding for some reason. I know it works locally, but see if there's something in the camera configuration that is required for remote viewing that is not set right.
- NhellieVirtuosoI agree with SamirD, it appears that the port is open but the target does not respond. What happens when you ping port 88 over the internet?
What error message are you getting when tracing 3504?
