Grant_Aksys
Sep 21, 2020Follower
How old is the BR200
I am in Canada. I was going to buy the BR500 from my distributor and they said that it was discontinued and replaced with the BR200. Is the BR200 better then the BR500? How long has the 200 been m...
schumaku
Sep 21, 2020Guru - Experienced User
Brand new product - it's first Insight Managed Business Router Data Sheet BR200 dates from 8-SEP-2020. Highly incomplete and not sufficient information provided there why ever. Reads to me like a BR500 stripped from the (not-so) fameous Insight Instant VPN feature.
ZenC
Sep 29, 2020Tutor
According to data sheet, BR200 only supports MD5 and SHA1 for VPN message authentication, while BR500 supports SHA1, SHA256, SHA384 or SHA512. Of course those are more secure. It it true that the successor BR200 now only supports SHA1 ??
- schumakuSep 30, 2020Guru - Experienced User
ZenC wrote:According to data sheet, BR200 only supports MD5 and SHA1 for VPN message authentication, while BR500 supports SHA1, SHA256, SHA384 or SHA512.
According to the BR500 Data Sheet there are only MD5 and SHA1 listed, too. It's under-marketed in the data sheet (the now no longer promoted Instant VPN stuf took by far to much room!) and the data sheet requires a review BretD please.
ZenC wrote:Of course those are more secure. It it true that the successor BR200 now only supports SHA1 ??
Still doubt these features are removed from the BR200 - here the relevant BR500 User Manual sections while the BR200 isn't avilable yet:
- ZenCOct 24, 2020Tutor
You're right, the data sheets for both routers only list MD5 and SHA1.
I got the confirmation that advanced hash algorithms are not available for the BR200 on a site-to-site VPN. You cannot build a site-to-site VPN with advanced hash algorithms. This is not good practice, especially for a product named business router. Therefore, comparing the User Manual of BR500, this feature seems to be removed indeed from the BR200.
BretD: Is this information correct?
There is OpenVPN available, but it can be only configured as VPN access point for clients, no site-to-site.
Will this be added in a later firmware release? Right now I wouldn't consider the BR200.
