ticedoff8's avatar
ticedoff8
How to enable SSH on BR200 Firewall?
I have a new BR200 firewall (replaced an old ProSafe FVS318G).
How do I enable SSH in the BR200?
I've looked in all the GUI screens in Basic & Advanced and cannot find anything about enabling SSH
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    ticedoff8,
    As far as I have checked the BR200 user manual here, SSH is not mentioned.  It is possible that SSH access is only for the higher tier of NETGEAR Support.
    DaneA
    NETGEAR Community Team
    • ticedoff8's avatar
      ticedoff8
      NETGEAR Moderator
      "As far as I have checked the BR200 user manual here, SSH is not mentioned.  It is possible that SSH access is only for the higher tier of NETGEAR Support."
      Yes, I checked the manual too.
      I have the WAC720 ProSafe wireless gateway that does have SSH and that is the only way I could dig myself out of the hole that was created when I upgraded its firmware and the new firmware did not support one of the "special" characters that I used in the password. Because it had SSH, I could PuTTY into the WAC720 using the old password and change it without having to start over again.
      I would place the BR200 on the same tier as the WAC720 in terms of business class network devices.
      This seems like a omission by NETGEAR.
      "SSH is not a feature on the BR200 unit as we do not allow internal access to the unit at this time."
      Being that the BR200 is relatively new, is anything on the roadmap for future releases of firmware that will enable / include SSH to the BR200?
      • schumaku's avatar
        schumaku
        The WAC720/730 has a more or less unofficial CLI (not a Linux shell) accessible by SSH.
        The BR200 does not have a CLI, so no need to open up an SSH access. For the unlucky password situation (caused by a late spec change i guess), a factory reset would have resolved the issue, too.
  • MrJoshW's avatar
    MrJoshW
    Hello,
  • Not sure you'd want SSH anyway as the Linux kernel version is pretty ancient (2.x, IIRC, based on an nmap scan I ran.) At that age SSH would be much more of a security risk than a benefit.
    • schumaku's avatar
      schumaku
      Agree jdrch . However, some simple testing tools like ping or traceroute, either from the local UI and/or Insight, or from a local shell would be the minimum.
ProSupport for Business
