rsjpx's avatar
rsjpx
How to Setup Remote Desktop Connection through WAN on FVS318G
Hi,   I'm having trouble setting up outbound/inbound rules to allow for Remote Desktop Connection through WAN.  Is there some tutorial or reference guidance page that I can use?  I'm behind a 4-por...
  • DaneA's avatar
    Nov 27, 2016
    Hi rsjpx,
    Welcome to the community! :)
    It seems that the 4-port modem you got is a combination of modem and router that is why the WAN IP address registered on the FVS318G is a private IP address.  I suggest that you set the 4-port modem to full-bridge mode so that the WAN IP address that will be registered to the FVS318G would be a public IP address.
    After you've done what I have suggested, you will need to configure an inbound rule to allow port 3389 for Remote Desktop Connection.  Kindly read pages 4-11 and  4-15 to 4-18 of the FVS318G reference manual here about LAN WAN Inbound Services Rules and Inbound Rule examples respectively.
    DaneA
    NETGEAR Community Team
ProSupport for Business
