rsjpx
Nov 24, 2016Aspirant
How to Setup Remote Desktop Connection through WAN on FVS318G
Hi, I'm having trouble setting up outbound/inbound rules to allow for Remote Desktop Connection through WAN. Is there some tutorial or reference guidance page that I can use? I'm behind a 4-por...
- Nov 27, 2016
Hi rsjpx,
Welcome to the community! :)
It seems that the 4-port modem you got is a combination of modem and router that is why the WAN IP address registered on the FVS318G is a private IP address. I suggest that you set the 4-port modem to full-bridge mode so that the WAN IP address that will be registered to the FVS318G would be a public IP address.
After you've done what I have suggested, you will need to configure an inbound rule to allow port 3389 for Remote Desktop Connection. Kindly read pages 4-11 and 4-15 to 4-18 of the FVS318G reference manual here about LAN WAN Inbound Services Rules and Inbound Rule examples respectively.
DaneA
NETGEAR Community Team
DaneA
Nov 27, 2016NETGEAR Employee Retired
Hi rsjpx,
DaneA
rsjpx
Nov 28, 2016Aspirant
Thank you DanaA! For some reason the FVS318G didn't receive a public IP address after I had set the modem to bridge mode. But after a couple of good hard resets to the modem, the FVS318G finally got a public IP address assigned to it.
- DaneANov 29, 2016NETGEAR Employee Retired
Hi rsjpx,
You're welcome! :) I'm glad you finally got a WAN Public IP address assigned on the FVS318G.
Feel free to post your future concerns here in the community.
Cheers,
DaneA
