djEnterprise
Oct 08, 2015Tutor
I Need HELP!!!
I recently purchased a FVS336gv3 and have had nothing but sleepless nights since. Here's the situation. Former Setup Zyxel VFG6005N Router (DHCP Server) TP Link TL-SG2424 (Switch) Windo...
- Oct 08, 2015
This sounds like the dns bug/issue.
Check the following:
- DNS proxy off
- Block udp flood off (and any other block/attack checks off)
- Assign the dns statically into the router
Let us know what happens.
DaneA
Oct 12, 2015NETGEAR Employee Retired
Hi djEnterprise,
As a follow-up, kindly answer the questions below:
a. Have you tried to connect a PC directly to the FVS336Gv3 then observe the internet connection?
b. What is the behavior of the WAN LED light and the port LEDs on the FVS336Gv3?
c. What is the current firmware version of the FVS336Gv3?
d. Have you tried to reboot the FVS336Gv3?
e. Have you tried to reset the FVS336Gv3 back to factory default settings?
I look forward to your response. Welcome to the community! :)
DaneA
NETGEAR Community Team
djEnterprise
Oct 14, 2015Tutor
Thanks for replying, to answer your questions
A) Yes (It would work fine, but once back under a domain environment it would fail)
B) All Green
C) version 4.3.3-5
D) Many Times
E) A few times
