Sorts
Jan 21, 2018Follower
I want to close port 443 to inbound traffic
I would like to to close port 443 to INBOUND and leave it open for outbound. How do I do this? I should say, I'm really unfamiliar with this, but I can log into my firewall configuration. I just do...
- Jan 23, 2018
Hi Sorts,
Welcome to our community!
For disabling the port 443, follow the instructions below:
- Login to firewall
- Go to Administration > Remote Management > Allow Secure HTTP management - NO
- Apply
- then check using a port scanner if it still open
- If still open, then look for the HTTPS service under inbound rules and delete it.
For enabling it on the outbound service:
- Go to Security > Firewall > LAN WAN Rules > Outbound Services > +Add
- Service : HTTPS
- Action : Allow always
- Specify the LAN and WAN users or leave it by default
- Then apply
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jan 26, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
