brianandrus's avatar
brianandrus
ICMPv6 RA: ndisc_router_discovery() failed to add default route
I am seeing the following message in my logs every minute or so: [FVS318Gv2]Sat Dec 31 13:00:39 2016(GMT-0800) [FVS318Gv2][Kernel][KERNEL] ICMPv6 RA: ndisc_router_discovery() failed to add default r...
  • brianandrus's avatar
    brianandrus
    Jan 18, 2017
    I ended up factory resetting the router per support.
    So far things are good. I have not enabled ipv6 yet and will do so soon. So it appears that upgrading the firmware and then doing a factory reset is what was required.
ProSupport for Business
