Kerebel
Jul 03, 2017Aspirant
Impossible upgrade
Our FVS 336Gv2 routeur is running an old firmawre version : 3.0.9-02 After uploading the latest version, (4.4.3-6), unzipping the file, the Upgrade button processes (apparently) the .img file and re...
- Jul 03, 2017
OK, furthermore, the factory reste will change its IP to 192.168.1.1 as this sub network is 192.168.2.x ; I'll do it next time I go in this lovely region of Pau (France) !
Thanks !
DaneA
Jul 03, 2017NETGEAR Employee Retired
Hi Kerebel,
Welcome to the community! :)
Since firmware v3.0.9-02 is an old firmware version, I suggest you to upgrade the firmware in a ladderized manner. First, upgrade the firmware from v3.0.9-02 to v3.1.1-08. Then, upgrade the firmware from v3.1.1-08 to v4.3.1-18 and so on until you get to upgrade to the latest firmware v4.4.3-6. Be reminded to perform a factory reset on the FVS336Gv2 after upgrading the firmware to the latest version then reconfigure it from scratch in order to have a clean start using the latest firmware.
You may download the firmware versions for the FVS336Gv2 here.
DaneA
NETGEAR Community Team
