Kerebel
Jul 03, 2017Aspirant
Impossible upgrade
Our FVS 336Gv2 routeur is running an old firmawre version : 3.0.9-02 After uploading the latest version, (4.4.3-6), unzipping the file, the Upgrade button processes (apparently) the .img file and re...
- Jul 03, 2017
OK, furthermore, the factory reste will change its IP to 192.168.1.1 as this sub network is 192.168.2.x ; I'll do it next time I go in this lovely region of Pau (France) !
Thanks !
Kerebel
Thanks for your prompt answer.
As this routeur is located in a remote site, I suppose it's recommanded to upgrade it on site and not through our VPN from the head quarters ?
DaneA
Jul 03, 2017NETGEAR Employee Retired
It would be best if you perform the firmware upgrade on-site so that you can have physical access as well as you could observe the behavior of the LED lights of the FVS336Gv2 as you proceed with firmware upgrade process.
DaneA
NETGEAR Community Team
