jakecrew
Dec 27, 2019Aspirant
Install firewall
Should we install an extra firewall on our ISP provided router.
- Dec 29, 2019
If you will deploy another firewall router behind your existing router provided by your ISP, you will have a Double NAT scenario. To know more about Double NAT, access the article below:
To know the ways on how to solve issues (or prevent) Double NAT scenario, access the article below:
How to fix issues with Double NAT?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Dec 29, 2019NETGEAR Employee Retired
DaneA
jakecrew
Dec 30, 2019Aspirant
Thank you so much
