john-meyer
Oct 24, 2015Aspirant
integrating FVS318N-100EUS Router into network (dhcp, dns, ipadress conflict)
Hello, what was wrong: I replaced old ADSL Router/Firewall/WLAN/VPN Gateway with Netgear FVS318N-100EUS (dhcp off, DNS Proxy = default = ON) DHCP / internal DNS is served by Windows...
john-meyer
Oct 25, 2015Aspirant
Perhaps my fault was the "avm fritz reapeter 300e" which act has a WLAN AP (but it has no own DHCP Server)
My next Idea - active DHCP on Netgear for Range 192.165.5.230 - 250 and remove this range from the "original - main windows dhcp server"
adit
Oct 26, 2015Mentor
Do not run 2 DHCP servers on the same LAN. You will create an issue.
Which firmware is on the 318?
