BobC99
Jan 01, 2017Tutor
Internet disconnecting every 15 minutes (and home setup question)
My FVS336GV2 router block all WAN traffic in 15 minutes intervalls for about 6 minutes, including pings on the WAN side to the router. Here is what the sys log looks like Jan 1 12:35:39 2017((GMT...
- Jan 04, 2017
We connected the computer directly to the cable modem and it was doing the same thing, so we replaced the cable modem and looks like it is working much better now. No more loss of connection on the WAN side. Thank you very much for your help, you are the best!
DaneA
Jan 02, 2017NETGEAR Employee Retired
Hi BobC99,
Let us isolate the problem. Disconnect the FVS336Gv2 from the modem then connect a PC directly to the modem, are you able to go online just fine?
DaneA
NETGEAR Community Team
- BobC99Jan 02, 2017Tutor
Thank you, I will try this. The router is at another location so I cannot get to it until friday so I will try it then. I do have remote access to it though if I can do anything before that time, please tell me? BTW it seems to go down only when we are using it, I was pinging it over night, when it was not being used and it seemed to be fine...
- BobC99Jan 04, 2017Tutor
