chasdk54
Feb 10, 2017Aspirant
IP address translation
At work, we receive new equipment with controllers that have incompatable IP addresses. (Incompatable with our LAN) I have a handfull of IP addresses that I can use.but since the equipment has dozens...
chasdk54
Mar 02, 2017Aspirant
I would like to use the Prosafe FVS318G. Simply put, I have a programmable logic controller (PLC) running a piece of production equipment on our production floor. The IP address of the PLC is not compatable with our LAN. (I cannot change the PLC IP address) I need the Prosafe to accept a compatable (Static) IP address and translate it to the PLC's IP address (and vice versa). This will allow me to access the information in the PLC as well as program it from my desk at work. I do not need nor do I want any access to the internet or anyplace outside my plant. Can this device do this and if so, what direction can you give me?
Thanks!
DaneA
Mar 06, 2017NETGEAR Employee Retired
FVS318G has two versions: the FVS318Gv1 which is already EOL (End-of-Life) and the FVS318Gv2 which is available in the market.
On both FVS318Gv1 and FVS318Gv2, it is possible to change the default IP address to the IP range of the PLC. Kindly read pages 66-68 on how to edit a VLAN profile on the FVS318Gv2 reference manual here.
DaneA
NETGEAR Community Team
