mossdrive
Apr 06, 2016Aspirant
IPSec Issue
I have a SRX5308 and a FVS318N connected successfully via an IPSec tunnel. From the Monitoring>Diagnostics tab and I can ping the opposite gateway through the tunnel using the LAN address. I can also...
- Apr 12, 2016
Check the subnet masks/IP range for each side of your tunnel and make sure they match and also include the range you're trying to access.
DaneA
Apr 06, 2016NETGEAR Employee Retired
Hi mossdrive,
Welcome to the community! :)
Kindly answer the questions below:
a. Since you are able to get access on some hosts via the VPN tunnel, are there any software firewall/s or anti-virus installed on the hosts that you can't access via the VPN tunnel? If yes, kindly try to disable or uninstall it then check if same problem occurs.
b. What is the current firmware version of both SRX5308 and FVS318N?
c. Is the time and date synchronized on both SRX5308 and FVS318N as well as the hosts connected in each network?
I look forward to your response.
DaneA
NETGEAR Community Team
mossdrive
Apr 12, 2016Aspirant
DaneA wrote:Hi mossdrive,
a. Since you are able to get access on some hosts via the VPN tunnel, are there any software firewall/s or anti-virus installed on the hosts that you can't access via the VPN tunnel? If yes, kindly try to disable or uninstall it then check if same problem occurs. (There are no software firewalls on the network and the issue remians when the AV is disabled)
b. What is the current firmware version of both SRX5308 and FVS318N? ( v4.3.3-6 on both)c. Is the time and date synchronized on both SRX5308 and FVS318N as well as the hosts connected in each network? (All are using the same global NTP server)
DaneA
