mossdrive
Apr 06, 2016Aspirant
IPSec Issue
I have a SRX5308 and a FVS318N connected successfully via an IPSec tunnel. From the Monitoring>Diagnostics tab and I can ping the opposite gateway through the tunnel using the LAN address. I can also...
- Apr 12, 2016
Check the subnet masks/IP range for each side of your tunnel and make sure they match and also include the range you're trying to access.
SamirD
Apr 12, 2016Prodigy
