vpnbeginner
Sep 01, 2015Aspirant
IPSEC Site to Site FVS336 to FVS318
Hi Netgear Community, I want to set up a Site to Site connection between FVS336 and FVS318 at our costumer s office. At there site the FVS318 is behind a firewall. They forward ESP, AH and Port 500 ...
adit
Sep 01, 2015Mentor
You want the VPN router to get the public IP on it's WAN. If it is DSL service, you need to place the ISP router/modem in Bridge Mode.
If that is not possible, your only other option is to place the VPN router in the DMZ.
You should use Main Mode - Both Directions in almost all cases with a Site to Site VPN.
SA Lifetimes, 3600 if either WAN IP Address is Dynamic, 86400 if BOTH WAN IP Addresses are Static.
