yc16
Dec 05, 2016Follower
IPSec VPN between two FVS318's - only one has a public IP address
Hi all, I'm trying to connect a remote site to our main office over VPN, but I'm only given an internal IP address at the remote site. After doing some reading I found out it's possible to get IP...
Dan_Z
Dec 05, 2016NETGEAR Expert
Hi yc16,
Welcome to the community!
Suggest to use two public ip address to config ipsec vpn.Checked your configuration,found the wan ip address is mismatch.
Here is your configuration on IKE policy,the initiator side local wan ip and responder side remote wan ip is mismatch.
1.Iniatiator side [Local WAN:192.168.1.62,Remote WAN:162.x.x.x]
2.Responder side [LAN WAN:162.x.x.x,Remote WAN:76.x.x.x]
How to config IPsec VPN:
1.Get WAN IP address of Iniatiator side and Responder side:
Iniatiator(WAN1-IP)---(WAN2-IP)Responder
2.Disable all vpn policy
3.Edit Iniatiator IKE policy:Local WAN use WAN1-IP,Remote WAN use WAN2-IP.
Remote Endpoint for vpn policy config to WAN2-IP.
4.Edit Responder IKE policy:Local WAN use WAN2-IP,Remote WAN use WAN1-IP
Remote Endpoint for vpn policy config to WAN1-IP
5.Enable all vpn policy,then connect vpn.
Thanks,
Dan
