jimbo67
Aug 25, 2024Aspirant
IPv6 WAN PR60x
First of all, hi it must be the first time i cannot find my answer on the forum for years. So thanks for all the times i found the help i needed without asking. But after about 15 years using netge...
- Aug 26, 2024
Hi Jimbo,
The SSH or SDM is for tech support use only.
Currently PR60X does not support IPv6 on WAN or LAN, it is on roadmap for future firmware update.
Best Regards,
z
c3po2
Aug 26, 2024Apprentice
Hi Jimbo,
Best Regards,
z
- jimbo67Aug 26, 2024AspirantThanks for the answer c3po2.
They should add ssh login to it too for next update.
Why should it work only the "old" ms510txup and not on the new product ?
Its often faster to log on shh rather than click on all web gui settings to launch a ping...
I think i can live without ipv6 for the next few month.
I was never very confortable configuring it anyway.- jimbo67Sep 15, 2024Aspirant
Thanks for havind added wireguard on the last firmwire, it works great ( ipsec is such a pain when you often change network ).
Any idean when we could see ip6 support and maybe dot or doh support too instead of ip based dns.
Even if I'm not in a hurry it would be cool to have an idea ( weeks, months maybe never ? )
For now i'm using dnsproxy coupled with adguard-home to do such.
- c3po2Sep 15, 2024Apprentice
Glad to hear that WireGuard VPN worked great for you. We are adding new features with each maintenance release, the IPv6 and DoH are on roadmap but we don't have committed release timeline to share yet, customer feedback plays important role to sort priority. Thanks.
